Please help! Can't record in Audacity!
Hi,
Recently, a pop-up came up from audacity. It said “Recover Recent Projects?” which were just test (nothing important in projects). I clicked “NO” becuase I did not need them recovered. But audacity said that I can no longer record after i clicked no.
Anyway to fix this?
(Sorry if I was unclear)
It helps to write down (or attach an image of) the exact error message you see. Please see here for how to attach files: https://forum.audacityteam.org/t/how-to-attach-files-to-forum-posts/24026/1 .
If you are seeing “Error opening sound device” when you try to record, please see: http://manual.audacityteam.org/man/FAQ:Errors#sound_device .
Well, I’m trying to reinstall the program. I’ll see if that works.
Okay, uninstalling worked. I’m all set now… sorry for the trouble
