I’ve got PC (Win 10) and Laptop (Win 7)
Processor and memory are suitable for Audacity. Task manager shows it is loaded wery low level.
After updating to version 3 it was discovered that Audacity cannot play project. During playback sound from time to time stops (sound interrupted for 0.3 sec app.). Then playback continues. It goes app 15-30 sec then interruption again takes place.
Drivers were updated.
At PC I have got SSD for software. As soon as I put in properties to work with HDD (for session data) then project has problem in playback.
As soon as I put in properties use for data SSD then it goes OK.
If I put project in SSD - no issues. Playback is OK.
For laptop no matter what HDD I use. Issue still exists. No playback as should be. Only with interruptions.
Is it problem with sound card?
is it problem with software audacity?
is it new audacity feature that it is working OK only with SSD?
No idea at all
Peter, SSD is onboard (plugged into motherbord directly)
HDD is external. It is inside PC case but conected to motherboard through cables. Formatted NTFS. As soon as app works with SSD (sits on it and keeps session data including temporary) everything is OK
And what shall we do with laptop?((((( no poccibility to install SSD
