Hello you who are reading this and on before hand all the thanks!
I’ve recorded an audio in audacity (podcast) and this time we hooked up a guest per phone (as done earlier and then no problem) but when we finished I was to sit down and edit, audacity doesn’t support the audio? (Deeply concerned) And I get this error message…
-------ERROR MESSAGE--------------
This error message asks you to check the recording or playback device settings and the Audacity project sample rate.
There are three forms of this message
Error opening recording device - Error code -xxxx this means there is a problem with your Audacity, operating system or sound device recording settings, where xxxx is replaced by a numeric code.
Error opening recording device - Error code -xxxx this means there is a problem with your playback settings, where xxxx is replaced by a numeric code.
Error opening sound device … this is a generic message that is usually associated with a failure to start the audio stream.
These messages can suggest a problem with the drivers of the sound device, or possibly that you are asking the device to do something it cannot do. For example you will see this error if you attempt to Record to more channels than your device supports, or if you try to overdub on a device that can either record or play back but not both.
See the Numeric error codes section for details of the particular codes.
The recording device message most commonly occurs on Windows when one of the sound device inputs is not properly enabled or otherwise cannot respond to Audacity’s request to start recording.
And something must have been wrong when we recorded but I cant figure out what, is there anyway to fix this or am I doomed ((
