Play Cut Preview (what am I missing?)
Hi,
When editing audios or lectures, many times its desirable to CUT short segments, like when the speaker coughs or stutters. I see in the HELP section a Play Cut Preview with shortcut C. This would be GREAT and would eliminate trial-and-error selecting, Z (zero-crossing), cutting and test playing.
Though the Shortcut C does nothing, no preview, etc. It could be too early in the morning, so please excuse being dense.
-Ed
Please state which version of Windows you are using, and the exact three-section version of Audacity (look in “Help > About Audacity”)
If you are using the current 2.1.1, the special playback commands do not work, due to a bug.
As a workaround, each time you open a new project window, press Record then Stop. You can close the recorded track afterwards.
It’s Audacity 2.1.1 running on Win-7, 64 bit.
-Ed
Ok THANKS… I can deal with that. :smiley:
-Ed
