Play back with DVC 80
Trying to record from a cassette player using a Pinnacle VDC 80 I cannot control the playback speed. Otherwise the recording is strong. I found another software that would do the recording but I could not edit the results as I want. Is there something I am missing to adjust the right speed of the recording? Gene
Do you mean this
http://www.amazon.com/Pinnacle-Systems-210100316-Dazzle-Capture/dp/B0000C4DW1 ?
If so, it’s video capture, not audio capture. it may not work correctly with Audacity. Audacity cannot record correctly from a combined video and audio signal, it needs to be audio only.
If the other software can save a WAV file from the recording, import that WAV into Audacity.
