Hi there,
I’m new to the Audacity forum in which I use a Windows 7 computer. I am rebuilding my home studio for voice-overs and I’m planning to get a Behringer Xenyx Q802USB Mixer with USB. It has mic pre amps and compression which in theory would sound great.
Before I buy this mixer, I have to ask will this work with Audacity?
Any help will be most grateful.
Brian
Yes! Audacity works with (almost) anything that has regular Windows drivers, or anything that works with the Microsoft-supplied drivers. (I’m pretty sure this mixer is plug-and-play with the Microsoft drivers already installed on your computer.)
Note that it is an 8-channel “mixer” and you’ll get the 2-channel stereo mix out of the USB port. It’s not an 8-channel audio interface so you can’t use it for multi-track recording. (And, Audacity doesn’t really work for multi-track recording either.)
Also FYI - Your choice of recording software doesn’t affect recording quality (assuming nothing goes terribly-wrong
). The software simply “captures” the digital audio data coming from the drivers & operating system. However, if you apply effects every effect will sound different… Audacity’s reverb will sound different from everybody else’s reverb, etc.
