I want to change my pitch to 432 instead of the standard 440 for the A. After changing my pitch and saving my document, how can I tell that my pitch has been altered to the desired level?
Use “Change Pitch” or “Change Speed” with the % set to -1.818
If you have a really good sense of pitch (See Absolute pitch) then you will hear that it sounds a little bit “flat” (below standard pitch).
