Permanent Error opening Behringer sound device in Audacity
Win10 v1803 on Lenovo Thinkpad T560 with Behringer UMC404HD driver v4.38 and Audacity v2.2.2
I’ve tried to follow everything in the Audacity FAQ without success. Everything mentioned seems OK except: It says Check that the sample rate for the sound card matches the “Project Rate” in Audacity but I’ve not found that sample rate anywhere except in Audacity.
Help > Diagnostics > Audio Device Info… should show the rates the device claims to support. It does for all outputs but it doesn’t for any audio input device under MME or WDA. That line is always blank as follows:
Device ID: 1
Device name: Line In 1-2 (BEHRINGER UMC 404H
Host name: MME
Recording channels: 2
Supported Rates:
Any ideas what I’m doing wrong or how to get this working?
Many thanks for your help.
Have you tried updating to the current Audacity 2.3.0 version? https://www.audacityteam.org/download/
Do you still have the problem?
