Pause / Play / Stop Buttons in wrong location [SOLVED]
Running Windows 7 64 bit, Audacity 2.0.5. Installed through .exe
Every time I open audacity, the pause / play / stop bottoms are in the wrong location, covering up the “tools” so I am unable to select them. The buttons still work, but the tool selection does not. Screenshot attached.
I have tried uninstalling and reinstalling, but nothing has worked. Help!
View > Toolbars > Reset Toolbars if you want to dock all the Toolbars.
Reinstalling Audacity would also dock all the Toolbars as a result of resetting Audacity Preferences, but only if you enable the box “Reset Preferences” half way through the installer.
Thank you so much!
