pause button issue
hi
when I record an lp ill just start the record playing hit the record button and just let it go…i just let it record on its own till the record is finished…ive been seeing that somehow the "pause button gets pushed without me touching it.this is the 2nd time it get pushed with out me touching it…why is this happening?
benbernie
If you touch the P key on your keyboard by accident this will activate Pause. P is the shortcut for Pause.
If you want, you can go to Edit > Preferences…, Keyboard section. Type “pause” (without quotes) in the Search box. Then click on “Pause” in the list to select it and press the Clear button. Then pressing P on your keyboard will not Pause.
thanks
ok this time the pause button wasn’t activated…the wave editor just stiopped recording…I didn’t touch any button except the record button…and it stopped operation almost at the end of the side of the record…what can I do now?
benbernie
If it’s a USB turntable, disconnect and reconnect the USB cable and make sure it is tight at both ends. Also consider changing the cable.
Then reboot your computer.
Make sure Transport > Sound Activated Recording is not selected (not ticked).
hi
no its a non usb turntable…
benbernie
…almost at the end of the side of the record.
If it happened during the fade-out, is it possible that you’ve selected the [u]sound activated recording[/u] option?
what can I do now?
Record the last song again? :stuck_out_tongue:
ok thanks
