I recall a few versions back there was a feature called Paste Mix. That was rather useful for correcting a split stereo track which had channel drop outs. I’d copy and paste a small segment of one channel directly over at the same original poisition of the opposing track. Since this feature no longer exists in 3.6.1, might anyone know of a newer method to solve this dilemma? Thanks
That sounds like an old nyquist plugin called “repair_channel”.
Now the bad news: ̶ ̶I̶t̶ ̶d̶o̶e̶s̶ ̶n̶o̶t̶ ̶w̶o̶r̶k̶ ̶p̶r̶o̶p̶e̶r̶l̶y̶ ̶i̶n̶ ̶A̶u̶d̶a̶c̶i̶t̶y̶ ̶3̶.̶x̶.̶x̶, (It does work in Audacity 2.3.2)
Thanks for your reply. To the best of my recollection, this was not a plugin. From the Edit menu there were (I believe) 3 options to Paste | Paste Mix and Paste At Original Position.
The “latest version” work for me with Audacity 3.7.1. What’s the problem you are seeing?
Following additional testing, there is one major caveat: The effect does NOT work correctly if the track has real-time “time stretch”. If real-time (“non-destructive”) time stretch has been used, it is necessary to “Mix and Render” the track before using this effect.
This problem is likely to affect many other plug-ins.
It modifies both channels …
Sounds like a delay is added to both.
Update: now I see the problem : “stereo simulation” was enabled.
Ah yes, that will be it.
I’m not quite sure what is going on when the track has real-time stretch - can you figure it out @Trebor? One thing that confuses the issue is that when real-time stretch is applied, the visual waveform does not exactly match the sound - if you compare the visuals of a track with real-time stretch against a rendered copy of the stretched track, you will see that the waveforms don’t match.
Thanks for the help and this repair suggestion should do the trick. However, the article subject title still remains unanswered regarding the Paste Mix feature No Longer. Regarding the real-time stretch, my recommendation is to render the track first into a WAV or FLAC re-open and then apply the Repair option
WavePad feature ? , (not Audacity).
