I am working on a research project where in i need to give audio cues, for 4 minutes, but 1st beep in the right headset and 2nd one on left and alternating it…
I know it can be done manually but is there a way to toggle between the two.
I would really appreciate the help
Thanks
I’d say the easiest way to do this is to generate only the “right ear” beeps and then copy / paste that track and shift it to make the “left ear” beep track. Then just pan each one hard left / right.
Unless the left and right ears aren’t hearing the same thing. But you didn’t specify.
