Panning at specific value ( eg 4.5hz)
Hi experts
I am generating an audio
  1. It has 5 frequency combination
    Eg 100 hz, 200 hz, 300hz 400hz and 500hz
I want to pan the output audio at specific rate
Like 1.5 hz
Or 2.14 hz
Or 9.15 hz
Is it possible in Audacity?
There’s an Audacity plugin for that: panlfo2a.ny …
https://plugins.audacityteam.org/nyquist-plugins/effect-plugins/amplify-mix-and-pan-effects#panning-lfo
Hi Trebor
Thank you so much,
I downloaded the plugin, but i am not able to use it, perhaps i dont know how to
  1. i opened a stereo track
    now if i go to : Tracks and select PAN option i see only : LEDT -RIGHT-CENTRE options
if i go to effects i do not see the plugin.
can you help me?
After downloading you have to install the plugin …
https://manual.audacityteam.org/man/nyquist_plug_in_installer.html
Then restart Audacity, then the effect appears in the “n/a” folder in the effects list …
panlfo in audacity3
