Hi there,
I need to make a bunch of calls using a softphone installed on my windows 7 PC. If I get an answering machine I’d like to just play a recorded message from Audacity. I’m wondering if it’s possible to play from audacity directly to the stream the softphone is using. Or maybe it could, somehow, play to the mic input that the softphone is using.
Any ideas would be appreciated. Of if you could point me in the right direction. Thanks.
Joel
