i’m using mac OS 10.9.5
Audacity 2.0.5
i used the .dmg installer
i’ve edited files with several versions of Audacity numerous times and after opening a large file (172.8 mb) which is almost 3 hours long, when i try to play the file i get the error message “error while opening sound device. please check the output device settings and the project sample rate”
i can’t find where the output device settings are or the project sample rate.
when i open the MP3 file in ITunes it plays quite well. the problem is that i recorded a radio broadcast of a concert i attended a week ago while i was at a play and i want to edit out the parts of the broadcast that are NOT part of the concert, but can’t do so unless i can hear it within audacity.
