OSX 10.11 & XCode 7.3 IDE build - memoryX.h problems
Any developers working in this area ?
I’m a little stuck on Audacity/MemoryX.h
… Too many errors emitted, stopping
Things are looking good for all the other project parts, except for this main ? part - Audacity. Which I’ve no doubt will only be one of many after it.
It seems to be expecting a __MAC_OS_X_VERSION_MIN_REQUIRED <= __MAC_10_6
as in
#if defined(__MAC_OS_X_VERSION_MIN_REQUIRED) && __MAC_OS_X_VERSION_MIN_REQUIRED <= __MAC_10_6
hmm.
EDIT:
Let me be more specific.
This code extract is from MemoryX.h about line 363 - right before the #endif that starts this block - noted above , if <= __MAC_10_6
So the first error generated now is -
"Expected “;” after alias declaration - about line 380, and
“Unknown type name 'unique_ptr” - on about line 380.
I’m saying ‘about’ because I modified the file once, and moved the line numbers fractionally.
The first hides naked NEW and DELETE from the source code.
The second hides NEW[] and DELETE[].  Both of course ensure destruction if
you don't use something like std::move(p) or q.release().  Both expressions require
that you identify the type only once, which is brief and less error prone.
(Whereas this omission of [] might invite a runtime error:
std::unique_ptr<Myclass> q { new Myclass[count] }; )
Some C++11 tricks needed here are (1) variadic argument lists and
(2) making the compile-time dispatch work correctly.  You can't have
a partially specialized template function, but you get the effect of that
by other metaprogramming means.
namespace std {
   // For overloading resolution
   template <typename X> struct __make_unique_result {
      using scalar_case = unique_ptr<X>;
   // Partial specialization of the struct for array case
   template <typename X> struct __make_unique_result<X[]> {
      using array_case = unique_ptr<X[]>;
      using element = X;
   // Now the scalar version of unique_ptr
   template<typename X, typename... Args> inline
      typename __make_unique_result<X>::scalar_case
      make_unique(Args&&... args)
      return typename __make_unique_result<X>::scalar_case
      { safenew X(forward<Args>(args)...) };
   // Now the array version of unique_ptr
   // The compile-time dispatch trick is that the non-existence
   // of the scalar_case type makes the above overload
   // unavailable when the template parameter is explicit
   template<typename X> inline
      typename __make_unique_result<X>::array_case
      make_unique(size_t count)
      return typename __make_unique_result<X>::array_case
      { safenew typename __make_unique_result<X>::element[count] };
#endif
and yes, I know it’s not supported :slight_smile: - I am as usual working on my own, way out the front. Just hoping to catch the eye of anyone else working on advanced levels…
thanks
Robert
The developer of that code is “Paul Licamelli”. Try asking on the developer’s mailing list: https://lists.sourceforge.net/lists/listinfo/audacity-devel
