Orphans Abounding
For the first time in my 5+ years using Audacity regularly, I’m getting the following error with some frequency:
9:29:26 AM: Audacity 2.0.6
9:29:26 AM: Trying to load FFmpeg libraries…
9:29:26 AM: Trying to load FFmpeg libraries from system paths. File name is ‘avformat-55.dll’.
9:29:26 AM: Looking up PATH environment variable…
9:29:26 AM: PATH = ‘C:Program Files (x86)NVIDIA CorporationPhysXCommon;C:ProgramDataOracleJavajavapath;C:Windowssystem32;C:Windows;C:Windowssystem32wbem;C:Program FilesCommon FilesMicrosoft SharedWindows Live;C:Perl64sitebin;C:Perl64bin;C:WindowsSystem32WindowsPowerShellv1.0;C:POWERB~1BIN;C:Program Files (x86)QuickTimeQTSystem;C:Dwimperlperlbin;C:Dwimperlperlsitebin;C:Dwimperlcbin;C:Program Files (x86)QuickTimeQTSystem;C:Program FilesCommon FilesMicrosoft SharedWindows Live’
9:29:26 AM: Checking that ‘’ is in PATH…
9:29:26 AM: FFmpeg directory is in PATH.
9:29:26 AM: Checking for monolithic avformat from ‘avformat-55.dll’.
9:29:26 AM: Error: Failed to load shared library ‘avformat-55.dll’ (error 126: the specified module could not be found.)
9:29:26 AM: Loading avutil from ‘’.
9:29:26 AM: Error: Failed to load shared library ‘.dll’ (error 126: the specified module could not be found.)
9:29:26 AM: Loading avcodec from ‘’.
9:29:26 AM: Loading avformat from ‘avformat-55.dll’.
9:29:26 AM: Error: Failed to load FFmpeg libraries.
9:29:26 AM: Error: Failed to find compatible FFmpeg libraries.
9:29:39 AM: Warning: Orphan block file: ‘C:UsersOwnerDocuments1001The Tales1001 Book 051001 Book 05 Data268 Birth of Aslan_datae00d00e00000f1.au’
9:29:39 AM: Warning: Orphan block file: ‘C:UsersOwnerDocuments1001The Tales1001 Book 051001 Book 05 Data268 Birth of Aslan_datae00d00e00007f7.au’
9:29:39 AM: Warning: Orphan block file: ‘C:UsersOwnerDocuments1001The Tales1001 Book 051001 Book 05 Data268 Birth of Aslan_datae00d00e0000b6a.au’
9:29:39 AM: Warning: Orphan block file: ‘C:UsersOwnerDocuments1001The Tales1001 Book 051001 Book 05 Data268 Birth of Aslan_datae00d00e0000cd9.au’
9:29:39 AM: Warning: Orphan block file: ‘C:UsersOwnerDocuments1001The Tales1001 Book 051001 Book 05 Data268 Birth of Aslan_datae00d00e0000d42.au’
9:29:39 AM: Warning: Orphan block file: ‘C:UsersOwnerDocuments1001The Tales1001 Book 051001 Book 05 Data268 Birth of Aslan_datae00d00e0000d6b.au’
The only thing I’m doing differently is using an add-on called De-clicker.ny
I’m not noticing any actual problem with my sound files.
Windows 7 Home Premium SP1
Is Audacity crashing? You will usually see orphan files if you recover a crashed project, and Audacity will normally clean those up automatically when you save the project.
Is Audacity showing a popup message about orphan block files or any other error when you open the project normally?
Have you saved other projects or had other projects open? I think you will have to leave the orphans there and not delete them. There is a very rare issue where Audacity moves the AU files to the wrong _data folder. The misplaced files are then missing files in one project and orphan files (that don’t belong there) in the other project.
No crashes, no other projects open. The error shows when I attempt to open a project from the ‘Recent…’ menu.
If you find some steps that makes it happen, please let us know. Note that if you copy AUP files and _data folders in Explorer while the project is open, this creates orphans in the copy, assuming it has unsaved changes.
It is only safe to paste the copies in another folder. If you paste (or rename) in the same folder you can destroy your project beyond repair.
It happened again with a new project!
7:26:23 PM: Audacity 2.0.6
7:26:23 PM: Trying to load FFmpeg libraries…
7:26:23 PM: Trying to load FFmpeg libraries from system paths. File name is ‘avformat-55.dll’.
7:26:23 PM: Looking up PATH environment variable…
7:26:23 PM: PATH = ‘C:Program Files (x86)NVIDIA CorporationPhysXCommon;C:ProgramDataOracleJavajavapath;C:Windowssystem32;C:Windows;C:Windowssystem32wbem;C:Program FilesCommon FilesMicrosoft SharedWindows Live;C:Perl64sitebin;C:Perl64bin;C:WindowsSystem32WindowsPowerShellv1.0;C:POWERB~1BIN;C:Program Files (x86)QuickTimeQTSystem;C:Dwimperlperlbin;C:Dwimperlperlsitebin;C:Dwimperlcbin;C:Program Files (x86)QuickTimeQTSystem;C:Program FilesCommon FilesMicrosoft SharedWindows Live’
7:26:23 PM: Checking that ‘’ is in PATH…
7:26:23 PM: FFmpeg directory is in PATH.
7:26:23 PM: Checking for monolithic avformat from ‘avformat-55.dll’.
7:26:23 PM: Error: Failed to load shared library ‘avformat-55.dll’ (error 126: the specified module could not be found.)
7:26:23 PM: Loading avutil from ‘’.
7:26:23 PM: Error: Failed to load shared library ‘.dll’ (error 126: the specified module could not be found.)
7:26:23 PM: Loading avcodec from ‘’.
7:26:23 PM: Loading avformat from ‘avformat-55.dll’.
7:26:23 PM: Error: Failed to load FFmpeg libraries.
7:26:23 PM: Error: Failed to find compatible FFmpeg libraries.
7:26:29 PM: Warning: Orphan block file: ‘C:UsersOwnerDocuments1001The Tales1001 Book 051001 Book 05 Data269 The Word of Safety_datae00d00e00008ef.au’
7:26:29 PM: Warning: Orphan block file: ‘C:UsersOwnerDocuments1001The Tales1001 Book 051001 Book 05 Data269 The Word of Safety_datae00d00e0000dc8.au’
7:26:29 PM: Warning: Orphan block file: ‘C:UsersOwnerDocuments1001The Tales1001 Book 051001 Book 05 Data269 The Word of Safety_datae00d01e0001d45.au’
7:26:56 PM: Warning: Project check found file inconsistencies inspecting the loaded project data.
But it doesn’t happen for us (usually). Do you remember the steps you took in that project? Was it a recording, or an imported WAV file? Did you do copy, paste or something else in that project? Did you close and reopen the project without closing Audacity?
Did you copy of Save As… that project?
What you could do is use Windows to search inside files for those file names mentioned as orphans in the log, just to be sure those names are not inside another AUP file. If they are, those files will be “missing” in that other project.
Just like the preceding case, it was an original mono voice recording. It was handled as I have handled hundreds of previous projects.
We can’t see your computer, so what handling steps are those, exactly?
Did something change just before the problem started? Did you start using a different drive? Did you change Audacity version? Have you installed new computer clean up applications?
