Hi all,
In some need of desperate help here, I have an audacity project that is giving me the “Project check of ‘example_data’ folder found 68 orphan block file(s). these files are unused by this project, but might belong to other projects. They are doing no harm and are small.”
I get no tracks when I choose any of the three options and we desperately need the audio for a coursework project. It is something that needs to be sent to an exam board ASAP. Is there any chance of recovering from this error at all?
Please find log details below:
[i]17:51:21: Audacity 2.0.5
17:51:22: Trying to load FFmpeg libraries...
17:51:22: Trying to load FFmpeg libraries from system paths. File name is 'avformat-52.dll'.
17:51:22: Looking up PATH environment variable...
17:51:22: PATH = 'C:Program Files (x86)HP SimplePassx64;C:Program Files (x86)HP SimplePass;;C:Windowssystem32;C:Windows;C:WindowsSystem32Wbem;C:WindowsSystem32WindowsPowerShellv1.0;C:Program Files (x86)ATI TechnologiesATI.ACECore-Static;C:Windowsidmucommon;C:Program Files (x86)Windows LiveShared'
17:51:22: Checking that '' is in PATH...
17:51:22: FFmpeg directory is in PATH.
17:51:22: Checking for monolithic avformat from 'avformat-52.dll'.
17:51:22: Error: Failed to load shared library 'avformat-52.dll' (error 126: the specified module could not be found.)
17:51:22: Loading avutil from 'avutil-50.dll'.
17:51:22: Error: Failed to load shared library 'avutil-50.dll' (error 126: the specified module could not be found.)
17:51:22: Loading avcodec from 'avcodec-52.dll'.
17:51:22: Error: Failed to load shared library 'avcodec-52.dll' (error 126: the specified module could not be found.)
17:51:22: Loading avformat from 'avformat-52.dll'.
17:51:22: Error: Failed to load FFmpeg libraries.
17:51:22: Error: Failed to find compatible FFmpeg libraries.
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e000101d.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e000107f.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e00010c0.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e00010dc.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e000110f.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e000115e.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e0001183.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e000122f.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e0001248.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e0001252.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e0001258.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e000137f.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e000138e.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e00013a7.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e00013ab.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e00013d9.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e00013f6.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e0001408.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e0001425.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e000148c.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e00014fb.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e0001561.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e00015c7.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e0001660.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e0001661.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e0001670.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e0001679.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e00016af.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e00016f7.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e0001702.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e000174e.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e0001865.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e0001868.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e000187b.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e000188c.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e00018ad.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e00018c4.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e00018d5.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e000192c.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e000193a.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e000195e.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e000199f.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e00019eb.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e00019ec.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e0001a4f.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e0001a8f.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e0001af1.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e0001b10.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e0001b18.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e0001ba5.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e0001be6.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e0001c02.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e0001c17.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e0001c83.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e0001ced.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e0001cfa.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e0001ded.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e0001e43.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e0001e52.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e0001e6f.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e0001e71.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e0001ec2.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e0001ee7.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e0001f06.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e0001f23.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e0001f2a.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e0001f97.au'
17:51:22: Warning: Orphan block file: 'C:UsersmcarosstDesktopJames MoynihanJames Moynihan 2014_datae00d01e0001fe1.au'[/i]
Help is much appreciated!
