Order to apply Effects? Using the "fuzzy rule" does...
Audacity 2.3.0 ~ Windows 10
…anything jump out as totally wrong with the order I apply my effects?
1-AutoTune
2-Normalize
3-Compressor
4-EQ
5-Noise Reduction
6-Delay
7-Reverb
Thank you,
yeto
We’re working in a vacuum. What are you starting with and where you do you want to end up? That’s your voice, right?
IMO Noise-Reduction should come before AutoTune & Compressor.
AutoTune will also shift the pitch of noise which accompanies any out-of-tune notes,
so the noise-reduction profile won’t match those instances.
I agree, Noise Reduction should come early, before AutoTune, Compressor, Delay or Reverb.
Yes, it is my voice. I am happy with my current results but I just wanted to make sure that I was doing the steps in the proper order so that one step would not be detrimental to the next.
Is this sequence better?
1-Noise Reduction
2-AutoTune
3-Normalize
4-Compressor
5-EQ
6-Delay
7-Reverb
