Option for Export to FLAC is missing
Hi, I seem to be missing the option for Exporting an audio album to FLAC.
I know others have asked this question before, but maybe the problem is popping up again.
Has anyone else seen this problem or found a solution?
Checked version and downloaded again for good measure (3.7.7)
Thanks for any assistance!
Should have said - I’m running on WIndows 11 Home.
Go to Edit->Preferences->Modules and make sure mod-flac (and everything else) is enabled.
It seems like sometimes those settings are mysteriously changed.
There ought to be a button on the Export modal that takes you there.
It’s more of a weird technical quirk that it can be disabled like that to begin with. It should stop disappearing like that in audacity 4
Thanks everybody; really appreciate the quick response.
The flac module and a couple of others were disabled.
Looking forward to Audacity 4!
