HI! I’m here again hoping that someone may be able to help me. I have a kubuntu 25.20 machine, AMD. I’ve been trying to use the OpenVino AI music separator but not with mush joy. When i do try to use it it gives me this log error. 18:59:11: Error: In Music Separation, exception: Exception from inference/src/cpp/core.cpp:121:
Check ‘util::directory_exists(path) || util::file_exists(path)’ failed at frontends/common/src/frontend.cpp:113:
FrontEnd API failed with GeneralFailure:
ir: Could not open the file: “/snap/audacity/1212/usr/lib/openvino-models/htdemucs_v4.xml”18:59:13: Operation ‘OpenVINO Music Separation’ took 0.026000 seconds. Poll was called 2 times and took 0.000001 seconds. Yield was called 0 times and took 0.000000 seconds.
