Opening Audacity stops during verification process
Hallo, on my MacBook (13-inch Mid 2010, 2.4 GHz Intel Core 2 Duo, 8 GB RAM, macOS 10.13.6) audacity 3.4.2.0, which I used frequently and successfully on this computer, now gets stuck already while verifying “Audacity”. Even after a new installation the same problem occurs. Same happens with the current beta version. Has anyone an idea what the problem could be and how it would be solved?
Try to set up a testuser and look what happens then.
Do you have any antivirus programs installed?
Download and install the Intel version of Audacity, as opposed to the universal version.
I haven´t tried yet to set up a testuser. I´ll try it.
Thank you for your hint – the intel version works.
