Only getting one channel?
I’ve been doing recordings for a little under a year, and I’ve recently come across a way of improving them, yet hit another wall. I use a headset with USB connection, well it creates a sorta static which before was hard to fully remove even with several swipes of Noise Removal. Recently I decided to purchase a USB-to-Outlet adapter which drastically cuts down on the noise I got, and also purchased a 3 foot 3.5mm jack extension cable to connect to the mic jack without having to moving too many things around. Recently I tried recording a few things and saw that only the left channel was getting anything. I did a small test and it does work with the USB plugged in my laptop and no extension cable to jack, but the static feedback is something I didn’t want to deal with in the first place. Is there anyway I can get both channel to record again with my new little setup or am I going to have to revert to my old setup? Note: Beforehand I was always able to get stereo recordings.
Mic-In on the side of a Windows laptop is mono. It’s designed for a mono headset like this.
http://www.kozco.com/tech/audacity/pix/PCHeadset.jpg
You can cause Audacity to record in “real” mono which will play to both speakers in a stereo computer system. You’ll get a single sound track, but it will say Mono on the panel at left.
I’m pretty sure your headset microphone is mono… If you record in mono, a mono file will play through both speakers. If you record in stereo, you’ll only get one channel.
Try going to Edit → Preferences → Devices → Recording. Select your mic as the recording device and make sure “1 (Mono)” is selected for that input/device.
After recording, there are ways of downmixing stereo to mono, or copying the audio from one channel into both channels, or copying a mono track into both left & right channels of a stereo track, etc.
Recently I decided to purchase a USB-to-Outlet adapter…
You purchased a what???
How does that work with a USB mic???
Oh! I forgot to mention that I use Turtle Beach Ear Force x11.
Also the USB-to-Outlet adapter is similar to this: http://www.officedepot.com/a/products/204714/Kodak-USB-AC-Adapter/?cm_mmc=PLA-_-Google-_-Cameras_and_Camcorders-_-204714-IQ_PE%20&Channel=Google&mr:trackingCode=37176EF3-E753-DF11-BAA3-0019B9C043EB&mr:referralID=NA&mr:device=c&mr:adType=pla&mr:ad=19998017996&mr:keyword=&mr:match=&mr:filter=40292565596
Also the extension cable is because the way the headset is the few wires are short, cause they’d usually be used in a close area, within a few inches. I needed some length in order to be able to work as I am without parking my ass to the wall.
Also Will give the one bit a try, thank you. Will update if it works.
It did indeed work! Thanks for the help. It was just driving me stir crazy that I figured out one problem, but thought I created another. @_@
