Only able to hear 1st song of a 6 hour recording session
I’m using Windows 7 x64, SP1, Audacity Ver. 2.0.2
Recorded 8 megs worth of music but only able to hear the 1st tune only. Upon opening the file, I observed only the 1st song as been recorded and it is highlighted;
I do not know what I did and I do need help in retrieving my songs… :frowning:
8 MB for the default format of 32 bit float, 44100 Hz sample rate, works out as less than 1 minute for a mono track. :confused:
Thanks Steve… :slight_smile:
Have you worked out what the problem was?
Observed when I do a 3 hour session no problems, so that is what I’ll do in the future…
My guess is that you are using a high sample rate and you are running into this issue: http://wiki.audacityteam.org/wiki/Recording_length#long
That’s it Steve…I’m sampling at 96k… :laughing:
Thanks again.
