I want OLD Audacity,
Hi , so all the plugins I like are not working with the newer AUDACITY ,
Where can I get the old one , It had all the PLAIN GREY menu Panels , not the new blue bubbled menu
thanks
thanks
I don’t know what version you’re looking for, but [u]here are some older versions[/u].
As you probably know, using old software, hardware, or operating systems is a “loosing game”. Sooner or later you need to upgrade or replace one of the 3, and things are no longer compatible. (I’m running some old software myself and I still have a couple of Windows 7 computers, but I’ve been forced to upgrade on a couple of occasions, and I also have a couple of Win10 computers.)
Some old versions here: http://www.oldfoss.com/Audacity.html
Some older ones here: https://code.google.com/archive/p/audacity/downloads
Some others here: https://sourceforge.net/projects/audacity/files/audacity-beta/
Some others here: https://sourceforge.net/projects/audacity/files/audacity/
So does Audacity 2.2.1 if you select the “Classic” theme: http://manual.audacityteam.org/man/themes.html#classic
Which plug-ins? Are you sure that they are installed and enabled in the plug-in manager? http://manual.audacityteam.org/man/manage_effects_generators_and_analyzers.html
SLICKEQ and AMBIENCE Reverb.
AH , I had to select the ADD/REMOVE PLUGINS , I guess that’s obviously new
