prompt (subliminal.ny) was working fine but then started getting this message (see screenshot below) and now its not working. the error message is also not in my native language (English). Any ideas whats going on here? the subliminal.ny prompt is supposed to “convert” the sound from 44100hz to 17500hz
Not my native language either, but as an educated guess I’d say that it is telling you that the selected track must have a sample rate of 44100Hz (The actual sample rate of the track is probably less than 44100Hz).
If you search this forum you should be able to find an English version of that script.
Thing is its happened out of nowhere, was working fine before. Now every single track I try and convert this error message pops up. Tried reinstalling but no joy. Is there a solution??
Check the sample rate of the track in the track’s dropdown menu (click the three dots after the track name in the panel on the left end of the track).
