Hi,
I am currently converting cassettes to MP3. How do I add individual track numbers to songs. At the minute Audacity is recording the tape asone long song.
Thanks
Paul
Hi,
Thanks
Paul
You need to split the recording into one file per song. See: https://manual.audacityteam.org/man/splitting_a_recording_into_separate_tracks.html
If you want the tracks to play in sequence, you can create a playlist, for example a “M3U” file (https://en.wikipedia.org/wiki/M3U). Most media players provide the ability to create playlists.
Thank you for your reply.
Best wishes
Paul
