I’m using gentoo linux 64bit, audacity version 2.0.2 and my sound setup is only alsa. My old .asoundrc file used to do recording from system audio and recording from the microphone jack fine and a couple updates to things later it doesn’t work right. If I record from system audio it’s pretty low and distorted. I used to be able to record using a microphone cable going to my nintendo 2DS so I could record my music from korg dsn12. If I try to do that now, it has a few tiny audio skips and it changes the volume levels while it is playing.
My audio sources to record from in the mic dropdown are HDA Intel PCH: ALC269VB Analog (hw:0,0), Loopback: Loopback PCM (hw:1,0), Loopback: Loopback PCM (hw:1,1), sysdefault, and default.
My audio sources in the dropdown are HDA Intel PCH: ALC269VB Analog (hw:0,0), HDA Intel PCH: HDMI 0 (hw:0,3), Loopback: Loopback PCM (hw:1,0), Loopback: Loopback PCM (hw:1,1), front, surround40, surround51, surround71, hdmi, both, dmix, and default.
My current .asoundrc:
defaults.pcm.dmix.!rate 48000
defaults.pcm.dmix.!format S16_LE
pcm.multi {
type multi
slaves.a.pcm "dmix:PCH"
slaves.a.channels 2
slaves.b.pcm "dmix:PCH"
slaves.b.channels 2
bindings.0 { slave a; channel 0; }
bindings.1 { slave a; channel 1; }
bindings.2 { slave b; channel 0; }
bindings.3 { slave b; channel 1; }
pcm.both {
type route
slave.pcm "multi"
ttable.0.0 1
ttable.1.1 1
ttable.0.2 1
ttable.1.3 1
pcm.!default {
type asym
playback.pcm "plug:both"
capture.pcm "plug:dsnoop:PCH"
and here’s my old .asoundrc:
pcm.!default {
type asym
playback.pcm "LoopAndReal"
#capture.pcm "looprec"
capture.pcm "hw:0,0"
pcm.looprec {
type hw
card "Loopback"
device 1
subdevice 0
pcm.LoopAndReal {
type plug
slave.pcm mdev
route_policy "duplicate"
pcm.mdev {
type multi
slaves.a.pcm pcm.MixReale
slaves.a.channels 2
slaves.b.pcm pcm.MixLoopback
slaves.b.channels 2
bindings.0.slave a
bindings.0.channel 0
bindings.1.slave a
bindings.1.channel 1
bindings.2.slave b
bindings.2.channel 0
bindings.3.slave b
bindings.3.channel 1
pcm.MixReale {
type dmix
ipc_key 1024
slave {
pcm "hw:0,0"
rate 48000
#rate 44100
periods 128
period_time 0
period_size 1024 # must be power of 2
buffer_size 8192
pcm.MixLoopback {
type dmix
ipc_key 1025
slave {
pcm "hw:Loopback,0,0"
rate 48000
#rate 44100
periods 128
period_time 0
buffer_size 8192
I changed the .asoundrc because the old one was giving me playback issues on several programs.
