Not exporting
OS Mac Big Sur
Last time I used (2.4.2), worked fine, today did not export in any way, it hangs. Installed 3.0.0) and it is the same. The audio is a simple 2 minutes mp3 normalised. There must a be a switch somewhere, can not find it.
Please tell us more.
What is the name of the file you are trying to export? Where are you trying to export it to? What format are you trying to export in (MP3, WAV, etc)?
Does the project play back properly?
If I understand correctly you get the same error in 3.0.0 as you got in 2.4.2. Is this correct?
– Bill
Are you trying to export it to a cloud drive?
What is the name of the file you are trying to export? Arthur
Where are you trying to export it to? Desktop
What format are you trying to export in (MP3, WAV, etc)? Tried mp3, wav and aiff
Does the project play back properly? Yes
If I understand correctly you get the same error in 3.0.0 as you got in 2.4.2. Is this correct? Correct
I did not save the project before but just applied compressor and normalize, exported and worked. Now for a warning that it launched, first I opened a project, then imported the file, applied effects and it hangs when trying to export.
Never do that, all files in my drives
When you want to quote somebody’s words, drag-select the words and click the large quote marks above the message panel.
For example, these are quotes.
These are my words.
It’s easier to read.
What does that mean? What warning?
– Bill
You can not export a file by itself but a project, something like that.
Sorry, this is not working, I did the job in my old imac with version 2.4.2 as I always did, will try to solve the problem by myself.
Thanks
We can’t see your computer. If you tell us precisely what the message says, we will probably be able to help you.
