Hi,
I’ve just set up a Behringer umc404hd. I can’t record using all 4 inputs. The drop down menu on Audacity allows either inputs 1-2 or 3-4 separately. I assume this is because Windows 10 recognises it as the same!
Would please appreciate some help.
Thanks
There are some instructions [u]here[/u] but from what I see here on the forum a lot of people have trouble multi-track recording with Audacity.
You may need a [u]DAW[/u] (Digital Audio Workstation) application.
Thanks for info.
Couldn’t get all 4 inputs on Audacity. Managed to on Waveform though!
Best regards,
bdinghey
