I want to import wav files and normalize them on input. I’m able to do this on a windows, but I can’t find the option on my mac. Is there a way to turn this option on?
It’s the equivalent of “Normalize all tracks in project”
The option to “Normalize all tracks” on import was removed a couple of versions ago.
If you use the Normalization effect very frequently, you could create a keyboard shortcut for the effect: https://manual.audacityteam.org/man/keyboard_preferences.html
