I am using Audacity 2.0.2 with Windows 10
I recently changed the settings for the Normalize effect.
How do I return to the default setting. And what is that number?
check the boxes beside Remove DC offset and normalize amplitude to -1.0 db
At least that’s what it is for 2.1.2 on windows 8.1
Audacity 2.0.2 is very old now. Unless you downgraded due to Audacity’s “Internal PortAudio Error”, I suggest you obtain the current Audacity 2.1.2 from http://audacityteam.org/download/windows. 2.1.2 should save the settings of all effects, not just a few of the built-in effects. And if you click the “Manage” button in effects, there is an option to go back to Defaults.
The illustrations of Audacity dialogues in Audacity Manual are always the default values unless otherwise stated. So you can see the default values of Normalize for Audacity 2.1.2 at http://manual.audacityteam.org/o/man/normalize.html.
Thanks I reset my default settings for Normalize.
And I upgraded to 2.1.2
This was very helpful.
