Noise Removal
Hi - I have installed Audacity and an additional plug in. When I go to file - chained I see the new plugin. After I record I go to File - Chain - connect to program. The Voice Boost plugin does the enhancement to audio file. Then a box pops up and says “Your batch command of noise removal was not recognized.” When I go to close the popup box the enhanced audio file reverts back to a raw data file. Even without an audio file I do the same action going to file - chains and the box automatically appears. Do I need to re-install Audacity? Any tips would be helpful. Thank you. Paul
Which version of Audacity are you using?
What is the additional plug-in and where did you get it from?
Hi Steve,
Thank you for your reply. Installed is Audacity 2.2.2
