Noise removal
Most to the tracks I need to clean are voice talks so there is no complex sounds etc
I use the noise removal tool (in 1.3.4) and generally it does a good job, but there maybe a better way, but I’m not sure how to do it even though I’ve been using Audacity for quite a while :blush:
What would be handy is to be able to mute the sound below a certain level. i.e you would hear the speakers voice but the pauses in speech would be muted if you follow my reasoning…
Thanks for any ideas.
Steve
It’s called a noise gate. Try the second part of this post:
http://audacityteam.org/forum/viewtopic.php?f=12&t=1601&p=5918&hilit=noise+gate#p5918
Thanks for that, I’ve installed the LADSPA package for Windows so I’ll see how it goes :slight_smile:
Cheers
Steve
