I have just updated from 2.4.2 to 3.0.2 and have identified an issue with the Noise Reduction effect.
I am going through the normal procedure of selecting a small sample of audio at the start of my track, selecting Noise Reduction and Get Noise Profile.
I then get an error message:
‘Value Not in Range 0 to 24’
I have made no changes to my recording process. I am recording directly into Audacity.
I have tried altering the noise reduction and sensitivity settings to no avail. I have even tried re-installing and have read all I can on the Forum and Wiki.
This is something i have not experienced before on the earlier version of Audacity and would greatly appreciate some help as I have a lot to edit in the next few days.
Thank You
Helen
yes, I have been using the default settings, with
NR = 12
S = 6
FS = 3
this makes no difference.
Is it possible there is a bug in the noise profile generator?
Has anyone else noticed this problem?
is there a workaround, such as using a low-pass filter instead?
Im set to english (am in the UK)
Found my way into the regional number settings, and looks like it was set to European, with full-stops for decimals.
have re-started Audacity and it looks like its now working.
Thank you for the help, i was relly getting worried I wouldnt finish my project.
regards
Helen
I have the same problem and realized that changing my number settings to Metric caused the problem, but now I don’t know how the settings should be. Commas or full stops?
