Hi forum,
Here’s my version number for both OS and Audacity:
Audacity 2.1.0 (latest)
Mac 10.10.3 (Yosemite)
I’m trying to apply Noise Reduction as the first effect on a chain. I’ve tested many different methods according to the methods found on this wiki: http://manual.audacityteam.org/o/man/noise_reduction.html.
- If a Noise Profile exists, that Noise Profile will be used. It is often best to capture a suitable Noise Profile before running a Chain.
If a Noise Profile does not exist:
- If the Chain is applied to the current project, the current selection is used to create the Noise Profile. Therefore, other effect commands in the Chain will also only apply to that selection. If an export command is added, the entire file will be exported.
- If the Chain is applied to files, the first file (all of it) is used to create the Noise Profile. It may be useful to prepare a file containing a suitable Noise Profile and name it so that it is alphabetically the first file of those to be run in the Chain.
Setup for all repro steps below: four WAV files in a folder, the first one alphabetically is 10 seconds of near silence copied from one of the other three clips. Also the last effect in my chain is a WAV export.
Apply to Files, Repro Steps:
- Open audacity
- “Apply chain”
- Select four WAV files
What happens: transforms all four WAV files according to other chain effects (e.g., normalization, equalization, etc.) but does not apply the silence recorded in the first file. (Not sure this is a good implementation anyway, because the first file is processed according to the other effects so it’s ambiguous whether the profile is the processed near-silence file or the unprocessed one.)
Apply to Files with Noise Profile, Repro Steps:
- Open audacity
- Open one of the WAV files
- Grab 10 second profile (“Effect” > “Noise Reduction” > “Get Noise Profile”)
- Close file (tried both saving and not saving audacity project file)
- “Apply chain”
- Select all the WAV files assuming now the Noise Profile is saved (anyway to test this? allegedly as long as you don’t close Audacity the profile remains.)
Note: I’ve also tried using the “Get Noise Profile” button on the “Edit Chain” parameters menu.
What happens: transforms as above but no noise reduction.
Apply to Current Project, Repro Steps:
- Open audacity
- “Apply chain”
- “To Current Project”
Apply to Current Project, No Chain:
Just to be clear and assure you I know how to use this effect, if I apply it manually to a file it does work. I can tell because of the “L” and “R” output meters are zilch.
Anyone have luck with “Noise Reduction” in batch processing chains?
