Noise gate won't appear in menu
Hi, i have install de nyquist noise gate (.NY) file into de audacity nyquist folder. Re-start audacity, and i won’t find the noise gate (effect, generate or analyze roll menu).
Am i doing something wrong ?
need help (i’m a new user)
thanx :slight_smile:
Check which Audacity version you are using (Help menu > About Audacity).
The Noise gate effect requires a fairly recent version of Audacity 1.3.x. The recommended version is Audacity 1.3.13 which you can get here: http://audacityteam.org/download/
Download it, install it, test it and… it works !!!
thank you so much
