Please forgive me if I am asking on the wrong place.
I am a new user and the software has come with ezcap cassette music capture When trying to set up I notice there is no USB preference input option as suggested in the setup guide.
Can anyone help - or guide me to the correct part of the forum if I have asked in wrong place.
Thanks in anticipation of a response.
wyke
If you connect a USB audio device after launching Audacity, you must restart Audacity or use Transport > Rescan Audio Devices from the Audacity menu bar, so that Audacity sees the new device.
wow it worked - - it came up as USB PnP whatever that means.
Sorry to be so dumb but I think I now have an input so I need to look at how to clip and pastes stuff
so I will probably be back to pester if that is OK !!!
Wyke
