No Spectral Selection in Audio Track Dropdown Menu [SOLVED]
How come I have no Spectral Selections commands?
They are simply not there.
:frowning:
Cheers, Rick
version 2.0.6
Installed from exe
Win 7 home premium
64 bit
Did they exist in 2.0.6? They didn’t always used to be there.
Audacity 2.1.1.
http://audacityteam.org/download/windows
DOH!
I thought I had latest version installed :stuck_out_tongue:
In 2.1.1 and later, you can use Help > Check for Updates to take you to the download page where you can see if you have the latest version.
