no sound
I bought the audio technica direct drive turntable and after installing the software and setting up the input and output - I cannot seem to hear anything. I can see the input monitoring - flickering up and down as the record plays but even when I select the “output sound” I can’t hear anything. I have tried to turn up the volume but it doesn’t work.
If you see the red sound meters bouncing and the blue waves building themselves, then you are getting a recording, but you may just not be able to hear it.
It’s normal for older Audacity programs to come with equipment. You should upgrade your Audacity to 2.0.6.
http://audacityteam.org/download/mac
To listen while you are recording, choose the built-in output in Audacity’s Device Toolbar and enable Transport > Software Playthrough.
If you still can’t hear while you’re recording, get LineIn from Rogue Amoeba: Rogue Amoeba | What can we help you find?.
