I installed Release 3.2.5, and now there is no sound. Sound works with other applications, so problem is within Audacity. I tried running diagnostics and got “Received -9996 while opening devices”.
What computer and operating system are you using?
– Bill
Dell Inspirion 15 laptop Windows 10.
I’m a Mac guy. Hopefully one of the Windows elves will be able to help you out.
– Bill
TomC …I’m having the same problem…
Jademan said to check the slider (little rectangle) in the playback/speaker indicator at top. I moved it up and things are fine.
With audacity open press “CTRL + P” and select devices
What are Host, Playback, and Recording set to ?
Bob
Bob, thanks. I thought this was marked resolved. The problem was the “slider” was set low. I never noticed it because the playback appeared to be at high volume.
