Apologies i exceeded logins as i was on other pc and could not recall password.
I am on win 7 64 bit and Audacity 2.1.0 will not record from my computer any sound playing or any website sound. Here is a screenshot of my settings. There is no stereo mix on this pc. Not disabled or not shown it is just not on it
I got version 2.10 which is installed in C:\Program Files (x86)\Audacity
That is yours and not the portable one? Can i install v 2.1.1 over that? Thanks
Obviously we assume you have the copyright holders’ permission to record from the internet.
If Help > About Audacity… says “2.10” that is definitely not made by us. Whatever it says, I would uninstall that version.
Install 2.1.1 from http://audacityteam.org/download/windows. Half way through the installation, check (tick) the “Reset Preferences” box and say yes to reset preferences when you launch 2.1.1. Then you will start with clean Audacity settings.
If you got that 2.1.0 in your picture from http://portableapps.com/apps/music_video/audacity_portable it’s a modified version of Audacity. Audacity Portable is not our project so we do not know the full extent of their modifications.
