No Sound After Converting
Hi! I have recently installed audacity. I can record and hear files fine when they are in the Audacity program, but whenever I export files, no matter which kind that I convert them to, the tracks are silent. Please help! Thank you!
~Haru
While you’re recording, does Audacity look something like this…
http://kozco.com/tech/audacity/Audacity1_record.jpg
If not, then you’re not actually making a recording in Audacity. It’s possible to configure Windows so all the sound systems seem to work, but Audacity doesn’t get any music.
Windows Control Panel
http://audacityteam.org/wiki/index.php?title=Mixer_Toolbar_Issues#Using_the_Control_Panel
What are you recording and in what formats do you export? We live on tiny details.
Two of the most important pieces of information are missing: audacity version and operating system.
In which program are you trying to play the exported files?
If you import the exported files back into audacity do they play?
