no sound after converting to mp3[SOLVED]
I successfully record a demo in the audacity program. the problem is…there is no sound on the mp3. I have lame downloaded…I have tried many time…this worked fine before.
Many Thanks
John Voice over artist
One of our problems is using the same words but meaning very different things.
You can get a silent MP3 three different ways: There is no sound in the file, or there is, but the computer won’t play it for you, or the computer is putting the sound in the wrong place.
What happens when you open up the file in Audacity? Did everything come back and can you hear it?
Did you have the blue waves and bouncing sound meters at the point you exported the work?
Are you using a USB microphone? Which one? Describe the system.
Depending on where you get stuck, Export a show as a WAV instead of MP3.
Hi and Thank you for your response,
It just started working now on media player…I downloaded new updates…It is now working…I was dealing with…
Im using a usb Blue Yeti mich. The playback on audacity is fine and there is blue bouncing sound meters…I am using voices.com and they will only take mp3.
there was no audio on playback
Many Thanks
Hi Koz,
Its doing it again…Im using a usb Blue Yeti mich. The playback on audacity is fine and there is blue bouncing sound meters…I am using voices.com and they will only take mp3.
there is no audio again on the media player on playback
Dang…
John
When recording with a USB device you may have to disconnect the USB device when you want sound in Media Player, or set Windows to use the built-in audio device by default: http://manual.audacityteam.org/o/man/faq_playback.html#usb .
Okay, When I unplugged the usb mich…media player works.
Best John
