no Signal Vinyl recording
Hi there,
im using
Audacity 2.0.5
Mac OS 10.9.1 Maveriks
Focusrite Scarlett 8i6
All Drivers and Software are up to date.
I´ve done this before a lot of times with my old Tascam US 122 mk2 and it worked fine, but now i don´t find the problem.
so when i try to record, i don´t get any input signal in Audacity.
The Focusrite Software Scarlett MixControl shows me the input levels and it seems to be no problem recording this, but it won´t.
Interface is selected as input (OS and Audacity)
Sample Rates are set the same everywhere.
I Can´t find any more routing options in the Interface Software so maybe i´ve overlooked something!?
Any suggestions?
Thank you for reading
Audacity will fail if Stereo/Mono doesn’t line up. That’s set in Audacity > Preferences > Devices.
So the Scarlett software has a bouncing ball sound meter or something like that and it is working?
Apple (upper left) > System Preferences > Hardware > Sound > Input. Select the Scarlett and make sure that sound meter bounces.
I’m guessing it’s not going to.
The Scarlett 8i6 is an 8 in / 6 out audio interface
Now we’re in fuzzy territory. The device is expecting to play into a multi-channel recorder. Audacity can do that, but it doesn’t directly support ASIO and other advanced software. Make sure the number of sound channels matches.
Also, I don’t see any place to plug in a turntable. What are you using for a phono preamp?
Hi Koz!
Thanks for the help man!
As i said i did this a lot of times before so i basically just changed the interface.
TT > Mixer (A&H xone 32) > scarlett > mbp
Scarlett Software and System Prefs showed the input. Thats why i stuck there…
Problem was, as you suggested, the amount of channels…
I just barely understand why, and the other question now is:
Do i have now always six channels open while recording and then have to manually delete the 1. 2. and 5 and 6th channel afterwards?
Not a big deal, but an extra task…
Thanks!
b.
Yes. Audacity cannot choose which channels to record from. That’s a “feature request”. If you connect the turntable to channels 1 and 2, you might find Audacity will record those channels if you set it to record “2 channels”. If you connect to channels 3 and 4, it might record those channels if you set it to record “4 channels” then delete the silent channels 1 and 2.
To be sure Audacity always records the channels you want, you need to set it to record the maximum number of channels then delete the silent channels.
