Hi All,
New here: Running the latest Audacity on Mojave 10.14.6
This is a new problem.
I am not able to set audacity preferences for stereo files, only mono is available in the device preferences. I am trying to edit an mp3, not trying to record in.
This hasn’t happened before. Please suggest what I might try?
I’ve tried device preferences, I’ve tried mac audio preferences… no option/ drop down for 2 channel, only option is 1 channel. thanks, J
Which setting do you mean?
Do you mean the number of recording channels in “Preferences > Devices”? If so, then that only affect the number of channels when recording.
When you open a stereo file you should see two waveforms (left on the top and & right on the bottom).
If you only see one wave the original MP3 is mono. A true-mono file will play out of both speakers.
Or, it’s possible to have a stereo file with silence on one side. In that case, you’ll get one wave and one flat-line.
Or, it’s possible to have a “dual mono” file where the left & right tracks are identical. That can happen if you rip a “mono” CD because all audio CDs are 2-channels.
