On Ubuntu 18.04, I’ve compiled the current alpha version (2.3.1, evening of 1/10/19) with mod-script-pipe enabled. I’m able to use almost all of the commands (that I’ve tried so far) successfully. However, I can’t get Export2 to export with sound. I get a file output with the correct name, but a size of only a few hundred bytes (which appears to be the [correct] metadata, as it shows up with mediainfo), and no audio streams. No window appears to show export progress in the program. Using the Export dialog I can successfully export with the same track, name, etc.
Also, there could be a problem with m4a export, depending on the build of FFmpeg. I’d suggest testing it first with a format that is natively supported by Audacity (such as WAV).
Thanks, it helps actually… you know… following the instructions.
A bit more testing showed me the issue.
Export2: Filename=test.m4a NumChannels=2
doesn’t fail, it just saves the file wherever you are running Audacity from (of course, I expect there would be potential permissions issues, but not likely to be a problem for self-compiled). However, a previous command de-selected all of the tracks in my project, so the export was doing exactly as I asked and exporting exactly nothing. Adding
SelAllTracks
or whatever is appropriate before every export is the safe way to do it.
Yes, I expect so, though I’ve not actually tested that on a fully installed version on Linux.
(my test version of 2.3.1 is within my “home” user space.)
Glad you found it - that could have kept us going for a while.
