NEW VERSION
Hi
I saw an ad for a new version on facebook…
I installed it … thinking … should i really do this ?
got it … playing some text to speech on my comp and find thatt audacity isn t recording it !!!
( knew I should nt have messed about )
Am I going to spend the next 3 days trying to fix this prob !!!
Im on windows 10
thanks for any comment or advice !!!
the pref right now
https://images2.imgbox.com/f1/3c/tMxADTtD_o.png
Set recording device host in Audacity preferences to WASAPI to record the computer speakers …
Then you’ll have to close all Audacity Windows, then restart Audacity for that change to take effect.
think I may have solved it …
changed to windows wasap
changed to hi def windows loopback … this could be the key !
I remem though when I installed it did ask me … do you want to keep your settings and
I said yes…
so really , I should nt have had this prob !
But thanks for the good advice …
hi,
suddenly find that Im not manageing to record an aduio signal from a cassette player fed into the computor
Im getting sound ok in the computor speakers but I press record on audacity and just a flat line.
Im manageing to record audio from U Tube etc no probs
Any idea why I suddenly cant record audio from this line in ?
my main settings are …
windows wasap
speakers realtek hi def loopback
sterio recording channel
speakers realtech hi def
thanks for any comments or advice …
STRANGE… I just changed wasap to … windows direct sound… and now find I can
record from this cassette music centre ! but now the U Tube signal will not appear in there !!!
will I have to just change between those two … ? wasap when I want to record U tube or internet radio
and windows direct sound when I want to record by line in ?
“WASAPI loopback” should only be used for recording sounds that are playing on your computer.
