Hello. I am switching from Audio Audition to Audacity. I routinely record a meeting for which I only need a portion of the meeting for a podcast. How to I select a point and then delete everything up to that point? How do I select a point and then delete everything after that point?
Thanks.
The easiest way to do this is to just select the portion you want and then use Edit > Remove Special > Trim Audio or its shortcut Ctrl + T - or the Trim button in the Edit Toolbar
or if you do want to do it in two steps
move cursor to the first edit point
use Shift and the “Cursor to home” button in the transport toolbar - or just click and drag leftwards to the beginning
Edit > Delete or shortcut Ctrl + K
move cursor to the second edit point
use Shift and the “Cursor to end” button in the transport toolbar - or just click and drag rightwards to the end
Thanks. I’ll give this a try.
