New Starter problem
It states to set the Device Toolbar on the first “box” to Analog Connector (UA-1EX) but that does not seem available when I look. What am I doing wrong? Help this old dinosaur please.
Do you see anything that says “USB”?
The [u]Device Toolbar[/u] allows you to select the recoding & playback devices separately.
Try all 3 hosts (WASAPI, Direct Sound, MME). And try playing sounds through the device from Windows Media Player (or whatever you normally use).
Did you install the driver? (From what I found on the Internet it should work with the Microsoft-supplied drivers but then it might show-up with a generic name.)
If you’re still not finding it, go into the Windows Control Panel to make sure Windows is seeing it, and to make sure it’s enabled. (If you’re running Windows 10, right-click the Windows Speaker/volume icon and select Open Sound Settings.)
